Errors while compiling
ctesla75
Been thanked: 2 times
Post by ctesla75 »
Hi All,
After some issues getting an esp32 to compile to target it is now working, but my main program that works during debug displays no LCD. So i am trying to start slow. First flash an led next "hello" on LCD. The led flashes, But the compiler still brings up a lot of errors.
In file included from C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:110,
                 from C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\internals.c:568,
                 from ../main/esp-project.c:48:
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_Float.c:91:6: warning: conflicting types for built-in function '__builtin_isinf_sign' [-Wbuiltin-declaration-mismatch]
 char isinf(float f)
In file included from C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\internals.c:568,
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:876:13: warning: 'FCI_SCOPY' defined but not used [-Wunused-function]
 static void FCI_SCOPY(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:815:13: warning: 'FCI_SHEAD' defined but not used [-Wunused-function]
 static void FCI_SHEAD(MX_STRING sSrc1, MX_UINT16 iSrc1_len, MX_STRING sSrc2, MX_UINT16 iSrc2_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:795:18: warning: 'FCI_STRMOV' defined but not used [-Wunused-function]
 static MX_UINT16 FCI_STRMOV(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:771:18: warning: 'FCI_STRREV' defined but not used [-Wunused-function]
 static MX_UINT16 FCI_STRREV(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:701:17: warning: 'FCI_STRING_TO_FLOAT' defined but not used [-Wunused-function]
 static MX_FLOAT FCI_STRING_TO_FLOAT(MX_STRING String, MX_UINT16 MSZ_String)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:598:18: warning: 'FCI_NUMBER_TO_HEX' defined but not used [-Wunused-function]
 static MX_STRING FCI_NUMBER_TO_HEX(MX_ULONG Number, MX_STRING String, MX_UINT16 MSZ_String)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:531:18: warning: 'FCI_FLOAT_TO_STRING' defined but not used [-Wunused-function]
 static MX_STRING FCI_FLOAT_TO_STRING(MX_FLOAT Number, MX_UINT8 Precision, MX_STRING String, MX_UINT16 MSZ_String)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:476:17: warning: 'FCI_COMPARE' defined but not used [-Wunused-function]
 static MX_UINT8 FCI_COMPARE(MX_STRING sSrc1, MX_UINT16 iSrc1_len, MX_STRING sSrc2, MX_UINT16 iSrc2_len, MX_UINT8 iNoCase)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:450:13: warning: 'FCI_TOUPPER' defined but not used [-Wunused-function]
 static void FCI_TOUPPER(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:424:13: warning: 'FCI_TOLOWER' defined but not used [-Wunused-function]
 static void FCI_TOLOWER(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:331:10: warning: 'FCI_TOSTRU32' defined but not used [-Wunused-function]
 MX_UINT8 FCI_TOSTRU32(MX_UINT32 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:297:10: warning: 'FCI_TOSTRU16' defined but not used [-Wunused-function]
 MX_UINT8 FCI_TOSTRU16(MX_UINT16 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:254:10: warning: 'FCI_TOSTRS32' defined but not used [-Wunused-function]
 MX_UINT8 FCI_TOSTRS32(MX_SINT32 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:211:10: warning: 'FCI_TOSTRS16' defined but not used [-Wunused-function]
 MX_UINT8 FCI_TOSTRS16(MX_SINT16 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:182:18: warning: 'FCI_RIGHTSTRING' defined but not used [-Wunused-function]
 static MX_STRING FCI_RIGHTSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:159:18: warning: 'FCI_LEFTSTRING' defined but not used [-Wunused-function]
 static MX_STRING FCI_LEFTSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:129:18: warning: 'FCI_MIDSTRING' defined but not used [-Wunused-function]
 static MX_STRING FCI_MIDSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iStart, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:121:18: warning: 'FCI_GETLENGTH' defined but not used [-Wunused-function]
 static MX_UINT16 FCI_GETLENGTH(MX_STRING sStr1, MX_UINT16 iStr1_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:113:17: warning: 'FCI_GETCHAR' defined but not used [-Wunused-function]
 static MX_UINT8 FCI_GETCHAR(MX_STRING sStr1, MX_UINT16 iStr1_len, MX_UINT16 iPos)
[4/7] Linking CXX static library esp-idf\main\libmain.a
I am not sure if this is why the lcd didnt work but why are these errors coming up, the LED flashes
Has thanked: 593 times
Been thanked: 780 times
Re: Errors while compiling
I beleive those warnings look normal. Can you attach your project file so we can have a look at your program.
ctesla75
Post by ctesla75 »
Hi Ben , Thanks for looking at the errors. I have tried using different LCD's and different pinouts with no luck. I am only trying to get text on an lcd .
I am now wondering whether my esp32 is faulty. IT is a ESP32-wroom-32. There were no errors during compiling
lcd test.fcfx
(7.34 KiB) Downloaded 338 times
Has thanked: 156 times
Been thanked: 909 times
Post by mnfisher »
You are calling 'Start' repeatedly - move that to before the loop - it just needs to be called once..
Also add a delay to the loop (say 500ms) - the LED on the esp32 is flashing because the watchdog timer is causing an error. (Or add a loop with a delay after printing something to the display - as in this case it is just 'static' text)
ctesla75
Post by ctesla75 »
I have made changes as suggested but still no output, i will try a few different lcds tommorow, they are hd44780 LCD's as far as i know. They are second hand , taken from faulty equipment with working LCD'S
lcd test.fcfx
(7.51 KiB) Downloaded 264 times
Has thanked: 430 times
Been thanked: 647 times
You don't really need your loop at all just to display a single line for testing. You could just Start the display then print "Hello".
You might want to include a delay of say 50mS after the Start command as I think some older displays needed such. Also, have you set the contrast level and R/W pin?
The WiKi will provide generic connections (right click component then select Help) for these displays.
Has thanked: 704 times
Been thanked: 768 times
Just make sure your R/W is connected to GND and the pot is wired correctly.
A general rule is:
If you can only see a top row of squares, then there is a connection issue (including R/W not connected to GND) or LCD start has not been used.
If there is more than one row of black squares, then the contrast i.e pot settings are the issue.
If nothing at all can be seen, then software or the contrast (pot settings) could be the issue.
ctesla75
Post by ctesla75 »
Thanks for the replies.
I have updated the code and removed the loop, I also added a delay ,set r/w to ground and fixed the contrast.
But still no luck. I get one line of blocks the contrast seems to work fading it in and out but no characters. I tried using the first 4 bits db0 - db then db4 - db7. but still nothing. the lcd is a tc1602a-09t and i looked up the datasheet. so think its wired up right\
lcd test.fcfx
(7.29 KiB) Downloaded 287 times
Sounds like you are getting close.
The generic 16x2 component uses the "4-bit" interface and uses the upper bits (D4-D7) which are pins 11-14 on the display.
A quick search on the web suggests that the chip is a clone of the Hitachi chip but I see that some people have seen some timing issues.
ctesla75
Post by ctesla75 »
Have been away from project ,just got back to trying again. I have put a usb logic analyser on the 4 bit interface , but data is only coming out of two pins. I have also put the print string comand back in a loop
