Compatible?
dogito
Compatible?
Post by dogito »
Hi. Does Flowcode support the Teensy 2.0, etc microcontroller family?
Has thanked: 755 times
Been thanked: 819 times
Re: Compatible?
Sorry, this is something that is currently not supported.
We do support the micro that's used (ATMEGA32U4)
I will move this topic to feature request and look into seeing if we can support the Teensy 2.0 family to work with the bootloader.
Has thanked: 300 times
Been thanked: 465 times
Re: Compatible?
We support the ATMEL chips used in the 8-bit versions of this board and so you should be able to produce code for it using Flowcode. The challenge might be in loading the code into the board via their bootloader and there may be additional linker settings required (e.g. to ensure your code does not overwrite their bootloader).
I suggest you contact the manufacturer of that device to find out if it is possible and if any special requirements are needed during the compilation process.
