Setting up the ESP 32 package in Flowcode9
igorakt701
Post by igorakt701 »
Good day. Please advice. I use the free version of FlowCode 9.I. I am the Package ESP32. After the expiry of the trial period 30 days Project with ESP32 stops compiling. The compiler gives a message that you do not During the test period, the project was compiled. The ESP32 package is installed in accordance with the instructions published on your site. What I need to make or fix it. As I have received the answer that I will be able to use the ESP32 package to use and after the expiration of the trial period
Has thanked: 292 times
Been thanked: 458 times
Re: Setting up the ESP 32 package in Flowcode9
In v9 the ESP target is not part of the free chips list and so compilation will stop after the trial period has ended.
In v10 the ESP32 target is a free target and perhaps you should consider upgrading to v10.
Has thanked: 616 times
Been thanked: 815 times
I beleive in v9 the ESP pack was free but you needed to apply your free license to get it. This might be as simple as clicking help -> licensing -> manage and then clicking My Flowcode license and signing in with your username and password.
Saying this.. You might be better off using v10 now as all the components there are free and some of the ESP32 devices are also included for free.
igorakt701
Is it possible to activate a free license of Flowcode 9 and if so, how? Please answer.
You should not need to activate to obtain the free licence. Flowcode will default to this once the trial has finished.
BenR wrote:
Thu Feb 02, 2023 10:36 am
Did you try the suggestion above?
If you are still having problems, can you please hold the "ctrl" key down when clicking to build your project and then upload your project file (*.fcfx) *and* the ".msg.txt" file that lists the compilation output here and we will investigate.
