ESP toolchain is not installed Parallels on M1 MAC
seokgi
Has thanked: 8 times
Been thanked: 8 times
Post by seokgi »
Hello?
I use M1 MACBOOK Pro. I am using FC9 through Parallels.
When I try to upgrade to FC10, the ESP toolchain is not installed. It seems that only x86 is supported.
Is there any way to install Parallels on M1 MAC?
And does it support ESP8266 (ESP-12F)?
I want to transmit data that is transmitted over serial through wifi.
Thank you.
Has thanked: 593 times
Been thanked: 780 times
Re: ESP toolchain is not installed Parallels on M1 MAC
Are you getting any errors when installing the ESP toolchain? What are they?
Flowcode supports the ESP8266 as a slave to the MCU but we cannot currently compile code to run on it directly. The only ESP device we currently support as a microcontroller target is the ESP32.
seokgi
Post by seokgi »
When installing ESP-IDF, an error appears when running for the first time. It says that only x86 is supported.
Has thanked: 98 times
Been thanked: 294 times
