App Developer Expose to top level for variable not working
Has thanked: 245 times
Been thanked: 256 times
On my App I have 2 shape as mesh and I set the propertie mesh to " Expose to top level"
It's working perfect even in the deployd App version.
So I (the user also) can change the shape (mesh) while runing the App. Suport with a browsing to get the new mesh for each shape it's working perfect.
This should also work with a variable "filename_fmv" but when I choose "Expose to top level" there, the variable doesn't appear.
Now one more wish from me...
But then a browsing should appear the same as with file mesh for the shape, but then as .FMV by default. When I have finished selecting, I can open this .FMV file with my app with pressing a button "load_FMVfile".
At the moment i always have to open the same file with the same name because i can't browsing and choose
Example mesh file choose in running App:
Set properti mesh to top as meshtop and meshbot
In the deploid App choose via browser a new mesh file
Has thanked: 300 times
Been thanked: 465 times
Re: App Developer Expose to top level for variable not working
Hi Stefan,
I don't know if this helps, but in the latest update for v10 you can set a filename property to have a default file extension when the file dialog is opened. You set it up similar to the following:
custom filename filter.png (16.51 KiB) Viewed 1943 times
