Interrupts ESP32.
djebirmalik
Has thanked: 1 time
Flowcode v10 Interrupts ESP32.
Post by djebirmalik »
Hi,Hello everybody.
I'm making this post because I noticed that interrupts don't work with the ESP32.
I downloaded the latest FC10 patch xxxx , but nothing helped.
Regards.
Flowcode1.fcfx
Has thanked: 154 times
Been thanked: 886 times
Re: Interrupts ESP32.
Post by mnfisher »
What do you mean by 'doesn't work' - for example if the pin is connected to a switch you might get several interrupts due to bounce..
Also worth checking (using a terminal program - such as PuTTY) that the esp32 isn't spitting out some info.
djebirmalik
Has thanked: 1 time
Hi,Martin;
The simulation does not work. Regards.
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Post by p.erasmus »
I might be wrong however I still have the view Interrupts are not supported in Simulation
djebirmalik
Has thanked: 1 time
Flowcode v10 Re: Interrupts ESP32.
Hi,Peter;
No, the simulation does not work.Why ????? Regards.
Post by mnfisher »
It doesn't seem to work in sim - which is odd as you'd imagine the simulation engine was the same as other targets (it does work, for example on AVR)
Has thanked: 258 times
Been thanked: 415 times
I've confirmed the error and I will look into it. Thanks for letting us know.
I think the error can be fixed with a library update for the target device. We should have a new one for you soon.
djebirmalik
Has thanked: 1 time
In the meantime, thank you all.
Has thanked: 582 times
Been thanked: 761 times
Hopefully fixed for you now.
