Will the ATMEGA328PB be supported in the V10 release?
ATMEGA328PB
dz2869
- Has thanked: 1 time
- Been thanked: 1 time
- Has thanked: 292 times
- Been thanked: 458 times
Re: ATMEGA328PB
Please see the link posted in this post:
viewtopic.php?p=8199#p8199
Specifically:
Specifically:
Are there specific features of this device you would like to use that are not in the ATmega328 and ATmega328P? If not, then it appears you can use one of those targets instead.ATmega328PB is not a drop-in replacement for ATmega328 variants, but a new device. However, the functions are backward compatible with the existing ATmega328 functions. Existing code for these devices will work in the new devices without changing existing configuration or enabling new functions. The code that is available for your existing ATmega328 variants will continue to work on the new ATmega328PB device.
- Has thanked: 616 times
- Been thanked: 814 times
Re: ATMEGA328PB
The PB chip requires an updated compiler. I'm just looking at the latest version of the compiler to see if we can move to this without breaking too many things to allow us to support the more modern devices.
