Using C code
flowcode-developer
Has thanked: 19 times
Been thanked: 3 times
Flowcode v10 Using C code
Post by flowcode-developer »
I am using UART to get a string from a device. I then went to parse/trim that sting before I sent it to the PC. When I "compile to HEX" only the .h and .c files get generated. I think the problem is the C Code icon I am using. When I toggle it off the .hex gets generated. I have attached my code and the error message when the c code not toggled off.
Inspectra_macro.fcfx
(16.6 KiB) Downloaded 560 times
Inspectra_macro.msg.txt
(4.32 KiB) Downloaded 354 times
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Flowcode v10 Re: Using C code
Post by p.erasmus »
What you see is normal FC/Compiler will not generate a hex file if there is an error in the code,
You have an error in the way you are parsing the strings (I would think you should use a loop do that)
anycase the problem is that your C code generates an error and therefore the hex file is not generated
Has thanked: 302 times
Been thanked: 471 times
Re: Using C code
Your C code is illegal C. Specifically this line:
// Remove the first 3 characters from the string
FCL_BUFFER = FCL_BUFFER + 3;
FCL_BUFFER is declared as an array in Flowcode (local string "buffer[20]").
You are probably best off avoiding C code and using a calculation similar to following:
.buffer = Mid$(.buffer, 3, Length$(.buffer)-3)
Has thanked: 772 times
Been thanked: 833 times
Re: Using C code
To learn more string functions, you can also use within a calculation box:
.buffer = Right$ (.buffer, Length$ (.buffer) - 3)
As this is not a Flowcode bug, I have moved the topic from the Bugs section.
flowcode-developer
Re: Using C code
Thank you all! Where can I go to learn more about Length$, Mid$, Right$? They aren't C keywords and there isnt info in the Calculation Icon Properties wiki page.
Re: Using C code
You can find out about string functions on the Wiki here.
