from compiler message file
In V9 the pic compiler used is C:\Program Files (x86)\Flowcode\Common\Compilers\pic\bin\xc8.exe which compiles correctly
In V10 the compiler used is C:\Program Files (x86)\Flowcode\Common\Compilers\pic\bin\xc8-cc.exe which does not compile
please advise solution, I've had a look under compiler options but I cannot see where the .exe is speciifed
compile error when build to hex
Maverick
- Has thanked: 27 times
- Been thanked: 8 times
- Has thanked: 704 times
- Been thanked: 768 times
Re: compile error when build to hex
Hello the correct path should be
The path you specified is used for Flowocode v7 & v8 compiler only.
I'm surprised it worked for v9
With Flowcode closed, please download the correct compiler from this link.
If you are still having trouble compiling after, please post your .c .fcfx. and .msg.txt files.
If what I suggested works, can you please let me know?
C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\binI'm surprised it worked for v9
Thank you for the post and letting me know it's working.
As it's not a bug, I will move it from the bugs section.
At least if other people have the same issue then they know what to do.
