Icon´s!
Has thanked: 839 times
Been thanked: 205 times
Flowcode v10 Icon´s!
Post by jgu1 »
Hi MM!
After reinstall windows and all program, FC8, 9 and 10 on my laptop all my icon use the FC8 icon and if I doubleclick on a project made in FC10 it start
up in FC8, same in FC9 . But if I start the project via FC9 or 10 it start correct. Is it possible to change this, please?
Br jorgen
Has thanked: 724 times
Been thanked: 783 times
Re: Icon´s!
That sounds like a windows issue and not Flowcode.
It could be down to the order you installed the Flowocde versions.
Try this.
Make sure you can see file extensions as they are hidden by default.
To do that run windows explorer and select the View ribbon.
Make sure File name extensions is ticked.
Within windows explorer, right-click on any of your Flowcode project files with the fcfx extensions and select open with > Choose another app.
Select Always use this app to open .fcfx files.
Select More apps, then scroll down to the bottom of the list and click on Look for another app on this PC
Browse to
C:\Program Files (x86)\Flowcode v10\FlowcodeV10.exe
When completed, clicking on a fcfx file should open FC10.
Re: Icon´s!
Post by jgu1 »
Hi Martin!
Thank you, I Will try your suggest, you hear later today :D
Re: Icon´s!
Post by jgu1 »
Perfect Martin, now it is correct. thanks ;)
Br Jorgen
Re: Icon´s!
That's great!
Thanks for the update. :)
