fail to compile
Maverick
Has thanked: 27 times
Been thanked: 8 times
fail to compile
Post by Maverick »
Please advise why the attached does not compile, message file also attached
batt_sim_1.fcfx
(16.38 KiB) Downloaded 338 times
batt_sim_1.msg.txt
(1.76 KiB) Downloaded 306 times
Maverick
Re: fail to compile
Post by Maverick »
I have redone the fcfx in v9 which does compile fine
bsim1.fcfx
(12.96 KiB) Downloaded 294 times
Has thanked: 540 times
Been thanked: 725 times
Re: fail to compile
It's down to your font selection. The v10 project contains two fonts, a 24 pixel one and a 32 pixel numeric one which are both require fairly large amounts of ROM. The v9 project you created only has a single font which is the default 8 pixels high font which is much more concervative.
As your device is fairly limited in ROM memory then you can use a low pixel font and the gLCD SetFontScaler component macro to scale up the font on the display if you need bigger text sizes.
Hope this helps to explain things.
Maverick
Re: fail to compile
Post by Maverick »
Thanks for that, it seems to work
