Evening all! Can you add the above device. I've gotten hold of a couple. Got lots of program memory and features
Cheers
N
PIC 18F47Q84
WingNut
- Has thanked: 56 times
- Been thanked: 43 times
- Has thanked: 647 times
- Been thanked: 856 times
Re: PIC 18F47Q84
It's not in the current PIC8 compiler but we are looking to update the compilers and so hopefully will be possible to support soon.
Re: PIC 18F47Q84
I see the above PIC is now listed. Great and thanks. However the version I have is TQFP 44 pin form factor, which doesnt match the version in flowcode and hence the pin configuration isnt the same. How can i utilise this or does it require a separate component added to the library?
N
N
- Has thanked: 795 times
- Been thanked: 858 times
Re: PIC 18F47Q84
The 40-pin version is functionally identical to the 44-pin version, except the latter includes four additional pins marked as NC (No Connect).
While some pins are physically absent, all relevant pins are selected by name rather than their physical position, so layout differences don't affect functionality.
