ESP32 scan for ssid
WingNut
Has thanked: 50 times
Been thanked: 37 times
Flowcode v10 ESP32 scan for ssid
Post by WingNut »
Quick Q about this macro. It returns and index number to a max of 8. What determines which ssid is which index id. If for example i put this in a loop and prints the results to a screen, will it always be the same wifi connection for 0, for 1 etc? And what determines this? Is it signal strength?
Thanks in advance
N - esp noob
Has thanked: 593 times
Been thanked: 780 times
Re: ESP32 scan for ssid
Wifi routers with broadcast ssid enabled periodically send out their ssid. The esp simple listens for these messages and reports them in the order it receives them.
So no it won't always be the same order and is best to check the names of ssids from the scan before connecting.
WingNut
Post by WingNut »
Thanks Ben
