^ (1504) the PIC18 extended instruction set was enabled but is not supporte
solozerouno
- Has thanked: 2 times
- Been thanked: 2 times
error when i compiling led with pic18f45k22
solozerouno
Re: ^ (1504) the PIC18 extended instruction set was enabled but is not supporte
(908) exit status = 1
- Has thanked: 724 times
- Been thanked: 783 times
This is not a bug, so I have moved your post from the bugs section
The Extended instruction set is not required or supported by Flowcode
You will need to go into the Build > Project Options and change Extended instruction Set Enable bit from Enabled to Disabled.
For any future posts, it would help if you selected the 9 or 10 post icon, depending on what Flowcode version you have.
