Since I bought the software I haven't been able to compile anything with ESP32, I tried everything, used its installation method, uninstalled and uninstalled Python and ESP-IDF several times, installed several versions of it, including 4.1 that in the flowcode WIKI site recommend and nothing works. I also formatted my computer to install everything again and it doesn't work.
In this forum I see that version 9 has many problems to compile the ESP32.
I get this error:
ERROR:C:\.espressif\python_env\idf5.0_py3.7_env\Scripts\python.exe doesn't support asyncio. The issue can be worked around by re-running idf.py with the "--no-hints" argument.
I am using windows 11
Can someone help me to solve this problem?
Flowcode ESP32 Toolchain Installation problem
Ulises
- Has thanked: 1 time
- Has thanked: 616 times
- Been thanked: 814 times
Re: Flowcode ESP32 Toolchain Installation problem
I've also seen this om win11 and have a fix for the problem. I'll dig out my fix and let you know.
I've pushed the change to the library update system now so just go to Help -> Library updates and get the latest files from there and hopefully that will solve the problem for you.
Hello, are the libraries updated, and I still have the same error
Please try extracting the two attached files into this directory on your computer and see if this helps at all.
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ESP\Batch
Let us know how you get on.
- Batch.zip
- (2.07 KiB) Downloaded 836 times
it didn't work, it started to build, but now I get this error:
cc1.exe: some warnings being treated as errors
ninja failed with exit code 1
Running ninja in directory c:\users\ulises\documents\testflow\test3\build
Executing "ninja all"...
Build Failed
Auto close turned off
FINISHED
I am attaching the simple program that I am trying to build, I want to know if a more complex program with more components does not work because of the hobbyist license?
Device: ESP.ESP32.ESP32_WROOM_32
Generated by: Flowcode v9.3.0.35
Date: Monday, April 24, 2023 17:16:01
Users: 1
Registered to: Ulysses (60777485)
License key: 6B1BKY
NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Build Failed
FINISHED
Users: 1
License key: 6B1BKY
- Prueba3.fcfx
- (7.96 KiB) Downloaded 864 times
- Has thanked: 724 times
- Been thanked: 783 times
I got the same issue on win11.
I updated the components with the full database option, reloaded your fcfx project file and it compiled for me ok.
I made another program and had the same result, attached program.
Running ninja in directory c:\users\ulises\documents\flowtests\control_osmosis1\build
Build Failed
FINISHED
I was able to build just one program to turn on 2 LEDs, but if I start adding more components, construction errors begin.
I am in Mexico, if I travel to the UK with a new laptop and you install the flowcode with the toolchain for esp32, would it work?
I would like to know if I need to acquire the professional license to be able to build programs for ESP32?
Build Failed
FINISHED
- Control Osmosis1.fcfx
- (23.5 KiB) Downloaded 827 times
- Has thanked: 442 times
- Been thanked: 661 times
If you manage to compile any program, then it suggests to me that everything is installed correctly and perhaps the issue is elsewhere?
Looking at your file above I see that you have all switches and LEDs connected to the same pin (PortA:0), the Pot is Unconnected and the One-Wire is on the same pin as the LEDs and Switches.
Perhaps narrow down the issue by taking the file that compiles for you, then adding each component one at a time and seeing if it still compiles?
