Hi, I have installed Flowcode 10 and installed Pic16 compiler, when I try to compile my project a flag comes up saying
PIC compiler toolkit is not installed. Please visit http://www.flowcode.co.uk/ to download
This is all good but have now done that several time and also done a Repair to no avail.
After speaking to Someone at flow code, they asked me to enter the path into the pic compiler path as this is what happened when he installed it on his computer.
Still no Joy.
Can anyone help me and get my Flowcode10 working, its now been 2 weeks and still can not use it.
Many thank
Can not compile , down load toolkit, still not working
DarrenFronda
- Has thanked: 246 times
- Been thanked: 258 times
Re: Can not compile , down load toolkit, still not working
Hi DarrenFronda
Can you post your project file? (*.fcfx)
- Has thanked: 311 times
- Been thanked: 479 times
The "locations" tab of Flowcode's project options will show where Flowcode thinks the toolchains are located. If you look there and the 16bit compiler toolchain entry is wrong or missing, you can manually enter it there to fix the problem.
- Has thanked: 647 times
- Been thanked: 856 times
Sounds like you might need the PIC 8 compiler, this supports the 8-bit 10F/12F/16F/18F microcontroller devices.
The PIC16 compiler is for the 16-bit PIC devices which are the 24F/30F/33F microcontroller devices.
