Hello to this forums,
since I have Matrix V9, it was shown in the area of Library Updates "Flowcode Targets" these fault.
PIC16\24EP32GP202.fcdx, old version: Not genuine, New version: 2.
When I DownLoad the new version, it is not repaired. How can I fixed it.
Best regards
Kai
PIC16\24EP32GP202.fcdx not fixed
Rangnau
- Has thanked: 103 times
- Been thanked: 302 times
Re: PIC16\24EP32GP202.fcdx not fixed
Hi Kai,
Have you made a fix/edit to the version on your PC?
If so, could you post/attach it so that we can have a look and update our version?
I don´t know what you mean with that. I have carried out only a normal Downlaod. Please can you give me a support how shall I make this.
Best regards
Kai
Best regards
Kai
Hi Kai,
Did it not update to version 2?
Did you restart Flowcode?
Do you get errors with your project?
If so, can you post your project file (.fcfx) and the log (.msg.txt) file?
What do you mean?it is not repaired
the Update don´t take over to the Version 2. My Flow Code 9 is still working. I also install all the library's new, but nothing fix the problem.
Best regards
Kai
Best regards
Kai
Maybe your PC filesystem is corrupt?
Possibly try delete the file (24EP32GP202.fcdx) from C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PIC16
And try the update again.
I make it like your support. When I start flow code again and start the library update, it´s shown that the file is missing. And when I start the download, the report is still the same.
Best regards
Kai
Best regards
Kai
Very strange.
Please try copy of the attached file into
- 24EP32GP202.fcdx
- (33.16 KiB) Downloaded 592 times
