ESP32 toolchain failed
jandidden
Has thanked: 28 times
Been thanked: 12 times
Post by jandidden »
Earlier this year I struggled to get the ESP32 compile process going. After several installs, I got as far as the following error:
Running cmake in directory c:\users\jandi\onedrive_-_linear_audio\2a_-_ar_xt\esp32_wroom_log_scale_test-2\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32 -DCCACHE_ENABLE=1 c:\users\jandi\onedrive_-_linear_audio\2a_-_ar_xt\esp32_wroom_log_scale_test-2"...
ERROR: C:\esp-idf-tools\python_env\idf5.0_py3.7_env\Scripts\python.exe doesn't support asyncio. The issue can be worked around by re-running idf.py with the "--no-hints" argument.
Build Failed
At the time, I solved it, with help from members here, by re-downloading the ESP32 toolchain and selecting Python 3.8 instead of the default 3.7 in the ESP toolchain install process.
Recently picked up my project again, and found that the compile failed where it previously completed fine. I did an update of FC9 in the meantime so maybe that broke it.
Decided to re-install the ESP toolchain and after several failed attemps got it to progress to the previous error as shown above.
But now, in the toolchain install, there is no longer a selection of available Python versions, only V3.7 is available, and yes that fails.
Can anyone please help me to get this going again?
If you have a masochistic tendency, you may wish to look at all the other failed attempts I did here: viewtopic.php?p=11263#p11263
Jan
Has thanked: 510 times
Been thanked: 698 times
Re: ESP32 toolchain failed
Hello Jan,
I also get this problem. To fix it you can do the following.
Navtigate to this directory by copying and pasting the path into your file explorer address bar.
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch
Open the file esp32_build.bat in a text editor by right clicking and selecting edit.
Find these lines.
@idf.py build
REM @idf.py --no-hints build
Move the REM up a line so you get this instead
REM @idf.py build
Save and close the file.
Now repeat with the file esp32_prog.bat
These lines
@idf.py -p %PORT% -b %BAUD% flash
REM @idf.py --no-hints -p %PORT% -b %BAUD% flash
Change to look like this.
REM @idf.py -p %PORT% -b %BAUD% flash
Hopefully Flowcode can now compile correctly.
Not sure what has changed but if I make the change live for everyone it breaks existing working setups.
jandidden
Post by jandidden »
Ben, much oblighed (especially on a Sunday). I'll try that out asap.
Jan
jandidden
Post by jandidden »
On my system, the file path is slightly different (W10, FC9) but I found the batches and edited them.
The compile now progresses much farther without the 'asyncio' error but still fails; the first failure I can find in the output is from the CMake process:
[1/10] Performing build step for 'bootloader'
[1/1] cmd.exe /C "cd /D C:\Users\jandi\OneDrive_-_Linear_Audio\2a_-_AR_xt\ESP32_wroom_log_scale_test-2\build\bootloader\esp-idf\esptool_py && C:\esp-idf-tools\python_env\idf5.0_py3.7_env\Scripts\python.exe C:/esp-idf/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x1000 C:/Users/jandi/OneDrive_-_Linear_Audio/2a_-_AR_xt/ESP32_wroom_log_scale_test-2/build/bootloader/bootloader.bin"
Bootloader binary size 0x6710 bytes. 0x8f0 bytes (8%) free.
[2/8] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj
FAILED: esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj
What does that mean?
Edit: C compiles successfully
Edit2: The path (or files) 'esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj' do not exist.
There is no 'esp-idf/main'. Why the forward slash?
Jan
Aha move your project file from the one drive folder. Ideally to a file path containing no spaces. Projects didn't compile for me either when on a one drive folder.
jandidden
Post by jandidden »
That's funny, it all worked that way for years, I've been doing it since FC3.
It also worked well up to FC9 until the latest update a few weeks ago, so that doesn't point to a 'spaces in filenames' or OneDrive issue.
So has something been changed now that what worked before now doesn't?
It's also a major issue for me, having my user files on OneDrive/cloud is the basis for all my different PCs at different locations as I move around.
Jan
jandidden
Post by jandidden »
I moved the project to a folder on the local disk, with no spaces in it's path or name, also removed all spaces in the project name.
No change, still the same CMake failure as described above.
Jan
Has thanked: 142 times
Been thanked: 761 times
Post by mnfisher »
I did a fresh install..
See viewtopic.php?t=1108&start=80
Which works with v10....
