ST7796!
Has thanked: 839 times
Been thanked: 205 times
Flowcode v10 ST7796!
Post by jgu1 »
Hi MM!
Discover When I was making a counter, the number is not delete all when new number come. I mean if counter is shifting from 10 to 11 not all is deleted always after zero. I know I can use print " " for deleting but then the display "flicker" is there anything I can do so the 10 is complete delete?
Try simulate my program, same in real world.
I dont know if it is the same for ILI9488 an ILI9341.
Br Jorgen
Skærmbillede 2023-05-10 212223.png (1.07 KiB) Viewed 2918 times
ST7796_Standard.fcfx
(13.66 KiB) Downloaded 370 times
Has thanked: 163 times
Been thanked: 960 times
Re: ST7796!
Post by mnfisher »
One possible way to do it is to set the foreground colour the same as the background - re display the number then set colour to black again and display new number. This might be just as jarring visually as the 'space' technique?
(14.78 KiB) Downloaded 362 times
Ben's buffered output might help - or use the technique I used to do a fast display and draw to a buffer on the mcu..
RGV250
Has thanked: 46 times
Been thanked: 46 times
Re: ST7796!
Post by RGV250 »
It may not help but I normally print a space or two after the actual number.
Bob
Re: ST7796!
Post by jgu1 »
Hi Martin and Bob!
Thank you for reply. It look like Martin´s examble work. But is it a bug? :D
I have added a counter.
Br jorgen
(18.21 KiB) Downloaded 398 times
Re: ST7796!
Post by mnfisher »
Hi Jorgen,
How does it look on hardware? Is the 'clear' too noticeable? As Bob says - displaying a space (or spaces) after the number is a good way to handle this (but entails converting the number to a string first.
It's not a bug - it just occurs because the characters have different widths (a proportional font). So '1' is a lot narrower than '0'.
Re: ST7796!
Post by jgu1 »
Hi Martin!
It’s the the same on display as in simulation. And yes I know there as different way to clear and I Will tast the best way. Thank`s to both of you :D
Br Jorgen
