Problem with the interrupt Pic32mx150F128b
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Flowcode v10 Problem with the interrupt Pic32mx150F128b
Post by SpeedPIC32 »
Problem with the interrupt HC05 UART RXint 1 UART RXint 2
it simply does not work.
I can send data to the smartphone
nothing comes back.
I use HC05 6 PIN from AZ delivery.
with kind regards
SpeedPic32
HC05 Int.fcfx
(21.03 KiB) Downloaded 584 times
Has thanked: 470 times
Been thanked: 700 times
Re: Problem with the interrupt Pic32mx150F128b
I'm not too familiar using interrupts on PPS pins, but I think your chart may need to be modified.
At present you are looping around a decision based on the result of a calculation that takes place if an interrupt occurs. The interrupt could occur at any time.
Assuming the interrupt took place when you were in your "No" branch. The program would immediately jump to your interrupt and set your variable to "1". However you then have a delay of at least one second (possibly two depending on when the interrupt takes place) before you test the variable and subsequently look to receive the incoming string. You would need to be very lucky indeed for such an interrupt to occur just at the right time for you to test, branch and receive a string. If you are that lucky please send me your choice in this weeks Lottery draw :)
You might consider using a Circular Buffer (populated by RxChar called during your interrupt) instead, or try and capture the entire string in your interrupt branch then setting your variable.
I don't see any BlueTooth configuration so assume you have paired them previously and they are acting as a transparent link. Are they sending the "Nein" back to your phone OK?
Hope this helps.
SpeedPIC32
hello chipfryer27
I have tested your suggestion, unfortunately without success.
I then programmed a version with a PIC32MZ. see the appendix, which works like this.
I am convinced that the interrupt does not work with the PIC32MX150F128B. this would have to be examined / tested more closely.
With kind regards
SpeedPic32
HC05 Int.fcfx
(20.09 KiB) Downloaded 612 times
HC05 Int PIC MZ.fcfx
(20.3 KiB) Downloaded 483 times
WingNut
Has thanked: 56 times
Been thanked: 43 times
Post by WingNut »
I notice the interrupt says Enable RXINT3 in the flowchart but when you double click it to see how its set up, RXINT4 is highlighted
Do you have a USB-TTL serial converter?
If so use a Terminal program on your PC and connect directly to your chip UART Tx/Rx (check +5v/+3v level compatibility)
In your chart enable a RXINT for your connected port, then enter an endless loop doing nothing.
In you interrupt routine use RxChar to receive a byte then immediately use SendChar to send the received character back out.
Now whatever you type in your terminal program should be echo'd back to you.
Has thanked: 245 times
Been thanked: 257 times
Hi SpeedPIC32
Can you check if your PIC32MZ is MIPS32 ?
Change to MIPS32
SpeedPIC32
great that so many respond so quickly to this topic.
0. This is only about the RXint on the PIC32MX150F128B.
nothing else.
1. The interrupt on the PIC32MX150F128B does not work.
for this i uploaded you HC05 int. fcfx.
2. the interrupt on the PIC32MZ2048EFH100 works very well.
I have uploaded HC05 int PIC MZ for you.
I am of the opinion that the interrupt should always work like on the PIC32MZ2048EFH100, thanks to our software FC10.
3. these are the same programs just two different PIC.
4. This is exactly how I programmed a high-speed counter, for example.
5. can you check if your PIC32MZ is a MIPS32?
yes the PIC32MZ is a MIPS32 and also programmed that way.
6. the RXint is also correct. it always goes from 1 to 0 on channel 1, from 2 to 1 on channel 2 and in my case from 4 to 3 on channel 4.
because every first channel, input or output starts with the number 0 and not with 1.
I would be happy if BenR could take a look at this.
With kind regards
SpeedP'IC32
Thanks for the clarification. It wasn't too clear to me that your code worked on "x" but not on "y". Does sound as though it could be chip specific. No doubt Matrix will advise :)
SpeedPIC32
Flowcode v10 Re: Problem with the interrupt Pic32mx150F128b
I also think that it is chip specific.
would be good for me if it could happen quickly because I have to finish a project with the chip.
With kind regards
SpeedP'IC32
Has thanked: 635 times
Been thanked: 842 times
Im not sure if it's a problem with the interrupt or the baud rate of the UART. If you send out some data on the UART do you have anything you can use to check the timings are correct. It might be worth modifying the FPBDIV config setting to see if this makes a difference.
