After update!
Has thanked: 811 times
Been thanked: 203 times
Flowcode v10 After update!
Post by jgu1 »
Hi!
I have worked on a project for a while with an Ili9488 and an ESP 32, before Ben has made the Highspeed 80 mhz prescaler. The display has been fairly fast with the pin config I use in this project, up to 30 mhz working ok.
Now I have program the device again, not change anything, but now the display is suddently extremly slow :cry:
I have a backup backup try to program this also, same.
I started the project in FC9 and continue in FC10 all work until now. I try to program with FC9 (older) then it is fast.
Just like prescaler is on 6mhz.
please could this be fixed back again??
A project I have had a pcb manufactured for and spent many hours on this project, so not easy to change to the highspeed SPI
Jorgen
NewSun.fcfx
(180.95 KiB) Downloaded 326 times
WingNut
Has thanked: 50 times
Been thanked: 37 times
Re: After update!
Post by WingNut »
To be honest I've noticed the same with a Pic16f18877 project that i've been working on. Timing seems to be way off at 32Mhz. approx 4 seconds on a 1 second delay
Edit - sorry i should have said 'in hardware'
Has thanked: 429 times
Been thanked: 647 times
Re: After update!
Hi Wingnut
Four seconds on a one second delay sounds a bit PLL related. Is/Isn't 4xPLL enabled when it should / shouldn't?
I'd have a look at those as it's very easy to overlook in the configs.
Re: After update!
Post by jgu1 »
Hi again!
@wingnut I don´t know what happen with your project and your device, but mine is for ESP32 dev and the ILI displays.
Trying to investergate to get my old project to run again. I have perform some test The Ili9488 ESP32 SPI High Speed Modes is also slow.
The Ili 9341 and the ST7796 working still inESP32 SPI High Speed Modes, but slow if i not use high speed they are very slow.
Concerning my project which file do I have to roll back so I at least can try to finish my project, is it file for the display or the Esp32, please?
Jorgen
WingNut
Re: After update!
Post by WingNut »
It appears that the options had changed to external oscillator. Strange as i've been working on this for a while .. but its corrected
Has thanked: 590 times
Been thanked: 778 times
Re: After update!
Hi Jorgen,
The display component has new properties specific to the esp32. Make sure the fast pixels property is set to yes and give a generous buffer size. Maybe 40 or 80. Hopefully the display will be much faster than it was before.
Re: After update!
Post by jgu1 »
Hi Ben.
Many thanks for the info and fast reply, I didn't know that, but yes, I'm back again and it works as it should. Lovely.
Continue to have a nice weekend. :D
Br Jorgen
