Dug out an old project that uses EB1 hardware and worked fine, programmer and EB083 combo board. In the chart I enter a loop and wait until the button on Port A/2 is pressed. All good.
In v10 the component macro associated with reading EB083 Port A appears to have a bug. It doesn't detect the buttons being pressed. If I add in a button component allocated to the same pin (A/2) it works fine when the EB083 button is pressed.
Port B has the display and it's fine.
EB083 Port A
- Has thanked: 478 times
- Been thanked: 713 times
- Has thanked: 795 times
- Been thanked: 858 times
Re: EB083 Port A
Hi Iain.
Thank you for the report.
Would you like to try the attached component?
If it works for your project then it will be added to the component database.
- ComboBoard.fcpx
- (10.94 KiB) Downloaded 356 times
Re: EB083 Port A
Hi Martin
I put the file in Programdata/MatrixTSL/Flowcodev10/Components.
Compiles OK but I still cant read from PortA (bank 0) using GetSwitchState
If I use the GetPort command I can detect button press.
Re: EB083 Port A
Hi Iain.
My apologies, I uploaded the wrong file.
Attached should be the updated version.
- ComboBoard.fcpx
- (10.94 KiB) Downloaded 519 times
Re: EB083 Port A
Just to be clear, I'm using v10 with an EB006-30-9 programmer and EB083 combo. It's not to hand so I think it's the EB083.
It's only v10 that has an issue.
I opened up a previous (v8) chart in v10, made a couple of changes and had the issues described. With the new component, I deleted the existing combo then re-placed it, then recompiled but the problem remains.
I'll try creating a new chart with the new component when I'm next beside it.
PS
It's in hardware, not tried simulation.
PPS
Just tried in Sim, it works. Doesn't using a 16F1939 in the programmer/combo
PS
PPS
Re: EB083 Port A
Hi.
I have just tried using EB083 & EB006 with 16F1937 and the hardware is working as expected.
The only thing I have spotted with Flowcode simulation is the background of the quad 7seg component was invisible, so I have just sorted that out.
- Has thanked: 647 times
- Been thanked: 856 times
Re: EB083 Port A
Good morning Chipfrier,
Would you mind sending us your project and generated .C file so we can investigate further.
Re: EB083 Port A
Further info
Previously I was using my laptop running W8.1 with FCv8, 9 and 10 for the tests, results as above.
Today, using my W10 machine running FC10 I get a different result when using Martin's component.
I'm using a EB006-00-09 and an EB083-00-1 with a 16F1939 installed.
I created a new chart. This prints out blah blah on display then loops until Port A/2 is pressed. During the loop it displays the value of the variable used to read the switch. First time I included that.
In simulation the board suggests a key has been pressed but no value is returned.
In hardware looping around I get a value of 56 displyed which would indicate Port A2-A5 are pressed (they are not). Pressing any button makes no difference to the value. A0-A1 are set as digital and crystal is on A6-A7.
Pressing the buttons on the board illuminates the associated LEDs.
Further info
