I am long time beginner in Flowcode because have not free time for my hobby. So I learning step by step when I make new project. Now I am interesting about ways how to program PIC controllers and Arduino controllers. Is it only one way using RX/TX pins on it or is there other ways like I2C or something else?
I have PicKit 3 from old times and one programmer made by myself. It is use UART too. So is there any other ways how flash MCU?
You may attashed electric shemes too in this topic. Soldering PCB is not a problem because I use soldering iron from seven years old I was.
Any help and information I will be very thanks.
Regards.
Different solutions for flashing PIC MCU and Arduino.
Sergejs
- Has thanked: 75 times
- Been thanked: 5 times
kersing
- Has thanked: 81 times
- Been thanked: 65 times
Re: Different solutions for flashing PIC MCU and Arduino.
That is actually an exception to the rule. For programming using those pins to work the controller needs to be programmed with a boot loader. Dedicated programmers like PICkit (whatever version) and atmel-ice, to name just two of many options, use a specific protocol that is implemented in the chips when they’re being designed. That protocol is the only way to program a chip off the fabrication line. The big issue is that most manufacturers use a proprietary protocol so you need their hardware to program the device.Is it only one way using RX/TX pins
Once a bootloader has been programmed other communication means can be used like USB, uart, CAN and possibly I2C if someone takes the time to create a bootloader talking that specific protocol.
