How to make stable reference voltage source?
Sergejs
Has thanked: 75 times
Been thanked: 5 times
Post by Sergejs »
I try anything, but when battery slow to zero my reference voltage too. Is there any program or hard ware to fix it?
Has thanked: 163 times
Been thanked: 960 times
Re: How to make stable reference voltage source?
Post by mnfisher »
There's a circuit in this month's PE (practical electronics) magazine. If uses a mcp1501t chip as a 3.3v precision reference.
Sergejs
Post by Sergejs »
mnfisher wrote:
Wed Jun 07, 2023 7:09 am
Hi, Martin! I try to buy PE of this month, but nothing happen because I can not find how to buy in PDF format. May be, can you send me link please?
Regards.
Post by mnfisher »
https://www.electronpublishing.com/prod ... sues/2023/
The current (June) issue doesn't seem to be available yet.
Has thanked: 442 times
Been thanked: 661 times
Following on from Martin, there is unnecessary confusion by the publisher as subscriptions are available from Pocketmags
https://pocketmags.com/everyday-practic ... s-magazine
Do be careful regarding which issue you buy as they are a month "ahead". By that I mean in early June I received the July issue. Previews aren't too informative so be sure of your issue.
Whilst I subscribe, I'm a bit behind in my reading but I've had a quick look through the current issue (July 2023) and in the Multimeter checker/calibrator project it does describe a stable 3.3v circuit as Martin mentioned.
Hope this helps.
steve001
Has thanked: 81 times
Been thanked: 30 times
Post by steve001 »
HI,
The TL431L is a nice little programable reference
I posted an example the uses it here (2.5 Volts) , Please see amendment further down the post with the red block around it
When i drew that i hadn't had have enough coffee :mrgreen:
viewtopic.php?f=3&t=1671
There are quite a few calculators online for this also
Google " TL431 calculator "
Please be aware Precision references take time to stabilise, some cases this can be 20 Minutes
Hope this helps
