Flowchart webviewer
WingNut
Has thanked: 53 times
Been thanked: 38 times
Flowcode v10 Flowchart webviewer
Post by WingNut »
Not sure if there is already a feature on the books yet or not but I do a lot of forums reading while away from my 'flowcode machine'
It would be nice if I could view peoples uploaded flowcharts in browser. Including the older versions as often the different flowcode versions wont open in newer flowcode versions
Has thanked: 162 times
Been thanked: 958 times
Re: Flowchart webviewer
Post by mnfisher »
Ben has made one...
See https://www.flowcode.co.uk/FlowchartView/
WingNut
Post by WingNut »
Doesn't seem to work with .fcf files
Post by mnfisher »
I think he created it around v9 - so probably not.
It's possible to convert files using v7 - but as previous versions are now so far past 'support' - I'm not sure whether they would spend their time on handling them? Someone might like to create a 'converter' - but it depends on the format of the old .fcf files. The .fcfx are in XML and fairly easy to work with.
WingNut
Post by WingNut »
It would be a nice feature as there is a lot of 'how to do' info in the older forums
Has thanked: 291 times
Been thanked: 458 times
That old .fcf file format is not easy to work with or interpret and so your best option is to convert to .fcfx manually using Flowcode v7. It would be roo much effort to create a stand-alone .fcf -> .fcfx convertor.
WingNut
Post by WingNut »
Defeats the webviewer purpose then
WingNut wrote:
Wed Jun 07, 2023 2:02 pm
The .fcf file format was 'retired' over 10 years ago and all versions from v6 onwards have been using the new .fcfx format.
