Hello everyone
Can anyone here see where it's going wrong?
And how can I fix Flowcode v10 so I can run the file below?
And Attached filet:
Hope you will be helpful with suggestions to fix Flowcode v10 So I can use the ESP32 device.
With best regards
Monie
Can't compile the ESP32 With Display gLCD TLT9341
monie
- Has thanked: 1 time
- Has thanked: 696 times
- Been thanked: 767 times
Re: Can't compile the ESP32 With Display gLCD TLT9341
Hi Monie.
Your project compiles OK for me, so it could be down to your ESP toolchain installation.
Have you tried just compiling a blank project?
I have updated the Wiki ESP32 toolchain guide for starting afresh, I.e. uninstalling the whole toolchain and starting again.
Hi medelec35
I have gone through your suggestion but to no avail.
See below!
Build Failed
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch\esp32_build.bat reported error code
0x1
Attached filet: Do you have any suggestions?
So I can upload my codes without any problem
Best regards
Monie
See below!
Build Failed
0x1
Best regards
Monie
- Has thanked: 425 times
- Been thanked: 646 times
Your error message informs that Python is not installed. You must have that installed to use the ESP.
Please follow Medelec's instructions exactly and don't leave your PC alone as you may miss an option during the process.
Gets the following below all the time...
ERROR: Python is not installed...?
============================== Toolchain Check ==============================
git version 2.21.0.windows.1
ESP toolchain found at "C:\esp-idf\"
Building TestDisplayI2CRSP32-OK-Virker ...
Error: The following tools are not installed in your environment.
python
Please use the Windows Tool installer for setting up your environment.
Download link: https://dl.espressif.com/dl/esp-idf/ - Which of the options should I choose?
Using Windows v11
For more details please visit our website: https://docs.espressif.com/projects/esp ... setup.html
'idf.py' is not recognized as an internal or external command,
operable program or batch file.
Build Failed
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch\esp32_build.bat reported error code 0x1
Autoclose turned off
FINISHED
Tried to install "Python" but no luck.
Keep getting the above message.
Do you have a suggestion?
python
Using Windows v11
Build Failed
FINISHED
hi monie.
If you look at the instructions,
you will see that part of the esp-idf-tools-setup-2.3.exe install process is to install Python if it's not already installed.
It's the second image down.
Python is the first item that's installed.
chipfryer27 is spot on, you can't start the install then leave your PC, as there will be elevated requests and prompts for the destination paths, etc.
None, as the toolchain is downloaded from our website.monie wrote: ↑Tue Jun 13, 2023 7:37 amPlease use the Windows Tool installer for setting up your environment.
Hi medelec35
Which of the options is best to choose when using Windows 11 "ESP-IDF Windows Installer Download"
Open Source IoT Development Framework for ESP32
Download
See below 1 og 2
1: Attached filet: 2: Attached filet: Hope you will still be helpful with suggestions to fix Flowcode v11 so I can use the ESP32 device.
I have followed very closely
your proposal. But I can't get TestDisplayI2CRSP32 to work
With best regards
Monie
Download
See below 1 og 2
With best regards
Monie
Hi, monie.
Flowcode v10 is not broken as I have tried your project on a win10 PC and a win11 laptop and on both setups I get compiled successfully.
I have a couple of suggestions.
1. Run ESP-IDF which should be on your Desktop and enter then then and finally
Can you let me know what the reported idf, git, and python versions are please?
Also post within code tags the text from
2. Make sure the Flowcode component library is fully up to date by Help>Library Updates... Change the Files in-use to full database.
After updating reload your project.
Try compiling again
idf.py --versionCode: Select all
Git --versionCode: Select all
python --versionCode: Select all
install.bat esp32Also post within code tags the text from
install.bat esp32After updating reload your project.
Try compiling again
Hi medelec35
User:
1: python-3.11.4-amd64
2: Git-2.41.0-64-bit
3: esp-idf-tools-setup-2.3
4: c:\esp-id
Yes = Flowcode component library is fully up to date by Help>Library Updates... Change the Files in-use
With best regards
Monie
User:
4: c:\esp-id
With best regards
Monie
Hi monie.
For 1.
When I enter I get
I don't know why yours is so different if you followed Wiki ESP32 toolchain guide step by step
For 1.
When I enter
ESP-IDF v4.2.4-233-gfe907a6c39-dirtyMartin
