syntax error (876)
ramkrish_va
syntax error (876)
Post by ramkrish_va »
getting syntax error (876) while compailing, and the chip memory consumed is 72%
please help to resolve this issue
flow code version : v8.2.2.15(professional license)
Microchip MPLAB XC8 C Compiler (PRO Mode) V1.45
will it be resolved if i upgrade to v10
please help
Target folder: E:\AASHRITHA PROJECT FLOW CODE
Source name: E:\AASHRITHA PROJECT FLOW CODE\AASHRITHA PROJECT G+7.fcfx
Title:
Description:
Device: PIC.16F.16F18877
Generated by: Flowcode v8.2.2.15
Date: Monday, June 12, 2023 16:47:17
Users: 1
Registered to: Ramakrishnan
License key: YME6TK
https://www.matrixtsl.com
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat 16F18877 "E:\AASHRITHA PROJECT FLOW CODE\" "AASHRITHA PROJECT G+7"
E:\AASHRITHA PROJECT FLOW CODE>C:\PROGRA~2\Flowcode\Common\COMPIL~1\pic\batch\..\bin\xc8.exe --chip=16F18877 "AASHRITHA PROJECT G+7.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
Build date: Nov 15 2017
Part Support Version: 1.45
Copyright (C) 2017 Microchip Technology Inc.
AASHRITHA PROJECT G+7.c:
32871: #warning "This interrupt has previously been enabled, so the macro <TIMER1_INT> may never get called."
^ (162) #warning: "This interrupt has previously been enabled, so the macro <TIMER1_INT> may never get called." (warning)
32884: #warning "This interrupt has previously been enabled, so the macro <TIMER3_INT> may never get called."
^ (162) #warning: "This interrupt has previously been enabled, so the macro <TIMER3_INT> may never get called." (warning)
32910: #warning "This interrupt has previously been enabled, so the macro <TIMER4_INT> may never get called."
^ (162) #warning: "This interrupt has previously been enabled, so the macro <TIMER4_INT> may never get called." (warning)
32923: #warning "This interrupt has previously been enabled, so the macro <TIMER1_INT> may never get called."
32949: #warning "This interrupt has previously been enabled, so the macro <TIMER4_INT> may never get called."
32975: #warning "This interrupt has previously been enabled, so the macro <TIMER4_INT> may never get called."
32988: #warning "This interrupt has previously been enabled, so the macro <TIMER4_INT> may never get called."
33001: #warning "This interrupt has previously been enabled, so the macro <TIMER4_INT> may never get called."
33014: #warning "This interrupt has previously been enabled, so the macro <TIMER4_INT> may never get called."
33027: #warning "This interrupt has previously been enabled, so the macro <TIMER4_INT> may never get called."
33053: #warning "This interrupt has previously been enabled, so the macro <TIMER4_INT> may never get called."
33066: #warning "This interrupt has previously been enabled, so the macro <TIMER6_INT> may never get called."
^ (162) #warning: "This interrupt has previously been enabled, so the macro <TIMER6_INT> may never get called." (warning)
33079: #warning "This interrupt has previously been enabled, so the macro <TIMER4_INT> may never get called."
33092: #warning "This interrupt has previously been enabled, so the macro <TIMER4_INT> may never get called."
33105: #warning "This interrupt has previously been enabled, so the macro <TIMER4_INT> may never get called."
33118: #warning "This interrupt has previously been enabled, so the macro <TIMER4_INT> may never get called."
33131: #warning "This interrupt has previously been enabled, so the macro <TIMER4_INT> may never get called."
33144: #warning "This interrupt has previously been enabled, so the macro <TIMER6_INT> may never get called."
33157: #warning "This interrupt has previously been enabled, so the macro <TIMER6_INT> may never get called."
AASHRITHA PROJECT G+7.c: FCM_SERV_SAFETY_CHECK()
8779: }
^ (350) unused label "FCC_SERV_SAFETY_CHECK_A" (from line 0) (warning)
^ (350) unused label "FCC_SERV_SAFETY_CHECK_D" (from line 0) (warning)
^ (350) unused label "FCC_SERV_SAFETY_CHECK_E" (from line 0) (warning)
AASHRITHA PROJECT G+7.c: FCM_ARD_MODE()
12546: }
^ (350) unused label "FCC_ARD_MODE_D" (from line 0) (warning)
using updated 32-bit floating-point libraries; improved accuracy might increase code size
AASHRITHA PROJECT G+7.as: 11967: (876) syntax error
(908) exit status = 1
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat reported error code 1
Autoclose turned off
FINISHED
Has thanked: 618 times
Been thanked: 818 times
Re: syntax error (876)
Please can you attach your Flowcode project so we can investigate. To do this click on Full Editor and Preview and then click on the attachment tab.
