LED_WS82811 compiler error
mkopitovic
Has thanked: 1 time
Been thanked: 5 times
Flowcode v10 LED_WS82811 compiler error
Post by mkopitovic »
hi
For some reason, but I'm pretty sure that the problem starts after the last update (Flowcode v10.0.3.31) (I didn't see the problem yesterday) LED_WS82811 component stops the project from compiling. The problem is the same even if no other components are inside the project just an empty project and LED_WS82811 "initialise".
I tried it on several STMs error is the same
error message:
Flowcode1.c:158:75: error: 'FCVsz_06621_LED_WS28' undeclared here (not in a function)
MX_GLOBAL MX_UINT8 FCV_06621_LED_WS2811__RGB[FCVsz_06621_LED_WS2811__RGB][FCVsz_06621_LED_WS28[27][3];
Flowcode1.c:158:102: error: expected ']' before ';' token
Error(s) in build
thanks in advance
Has thanked: 478 times
Been thanked: 713 times
Re: LED_WS82811 compiler error
I tried just initialising the component in FCv.30 and it compiled OK using a PIC.
I updated to FCv.31 opened the file and got errors when compiling too:-
C:\Users\Desktop\New folder\Flowcode_31.h:158:52: error: (192) undefined identifier "FCVsz_06621_LED_WS28"
C:\Users\Desktop\New folder\Flowcode_31.h:158:75: error: (981) pointer required
C:\Users\Desktop\New folder\Flowcode_31.h:158:78: error: (981) pointer required
C:\Users\Desktop\New folder\Flowcode_31.h:158:78: error: (188) constant expression required
C:\Users\Desktop\New folder\Flowcode_31.h:158:78: error: (310) "]" expected
(908) exit status = 1
Error returned from [xc8.exe]
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
Autoclose turned off
Has thanked: 311 times
Been thanked: 479 times
Thanks, both. I'll have a look now.
Has thanked: 647 times
Been thanked: 856 times
Many thanks for letting us know.
Hopefully fixed for you now via the Help -> Library update window.
Compiles to Hex using a PIC fine.
mkopitovic
Has thanked: 1 time
Compiles to Hex using an STM fine also.
Thanks, both, for confirming the fix.
