Send EBM004 data via xbee
Rcm10
Hi! I´m doing a program in flowcode v6 monitoring the temperature that I get from the EBM004. I'm having a lot of trouble sending the data as both floats and integers. Any ideas on how I could transmit the data I receive from the sensor to another module to be able to display the temperature on the screen?
- Has thanked: 442 times
- Been thanked: 661 times
Re: Send EBM004 data via xbee
If using Flowcode v6 then please post in the correct forum for pre-V9 Flowcode releases.
https://www.flowcode.co.uk/mmforums/index.php
You will find greater support for legacy versions within, as this forum only relates to v9 onwards. You should maybe consider updating to v10 as v6 is quite old now.
You will also need to explain your issue better. What do you mean by "sending to another module"? Is that just a display attached to the same controller or a different controller connected somehow?
