ESP compiler error
Deg1
ESP compiler error
Post by Deg1 »
Hi have just started trying to compile with version 10.
The attached errors occur. Any thoughts please?
compiler window.txt
(3.51 KiB) Downloaded 436 times
Has thanked: 800 times
Been thanked: 865 times
Re: ESP compiler error
Hi.
First, If you post your fcfx project file, I can check it compiles for me.
If it does, then it will be a toolchain issue
The installation instructions are here, they will need to be followed by the letter as the ESP32 toolchain is very fussy.
grout1
Post by grout1 »
The problem is with esp ide configuration. I have installed VS Studio with espressif extension and used Flowcode generated C file.
That has compiled and flashed to esp device successfully.
I have given the location of the installed of esp ide used by VS to flowcode within Flowcode but even then when trying to build from flowcode it comes up with an error.
Python not installed!
In the meantime I'll just use flowcode to create the C file, which is great for me as that's the most important reason for using it.
