Compile error after FC10 update(Solved)
seokgi
Has thanked: 8 times
Been thanked: 8 times
Flowcode v10 Compile error after FC10 update(Solved)
Post by seokgi »
After a recent update, compile fails and an error appears.
Post compiler messages.
Target folder: C:\Share\Project\Ing\201008-SJ_HiTech-Auto_Lifting_Lamp_CTL\Program
Source name:   C:\Share\Project\Ing\201008-SJ_HiTech-Auto_Lifting_Lamp_CTL\Program\Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.fcfx
Title:
Description:
Device:        PIC16.24F.24FJ512GA606
Generated by:  Flowcode v10.0.3.31
Date:          Wednesday, June 28, 2023 13:40:33
Users:         1
Registered to: seokgi (1234)
Licence key: 1234
https://www.flowcode.co.uk
Using <PICkit4 IPE External Power> inbuilt settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC16\batchfiles\pic16_C30_comp.bat  "C:\Program Files (x86)\Flowcode\Compilers\pic16\" "Auto_Lifting_Lamp_CTL_230619-01-Up_Speed" "C:\Share\Project\Ing\201008-SJ_HiTech-Auto_Lifting_Lamp_CTL\Program\" "24FJ512GA606"
C:\Share\Project\Ing\201008-SJ_HiTech-Auto_Lifting_Lamp_CTL\Program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
C:\Share\Project\Ing\201008-SJ_HiTech-Auto_Lifting_Lamp_CTL\Program>REM REVISION: 1.0
C:\Share\Project\Ing\201008-SJ_HiTech-Auto_Lifting_Lamp_CTL\Program>REM GUID: 7821ABE5-9E21-4744-81B7-3FF600B75DB7
C:\Share\Project\Ing\201008-SJ_HiTech-Auto_Lifting_Lamp_CTL\Program>REM DATE: 08\08\2022
C:\Share\Project\Ing\201008-SJ_HiTech-Auto_Lifting_Lamp_CTL\Program>REM DIR: FCD\PIC16\batchfiles\pic16_C30_comp.bat
C:\Share\Project\Ing\201008-SJ_HiTech-Auto_Lifting_Lamp_CTL\Program>xc16-gcc -c -mcpu="24FJ512GA606" -omf=coff -funsigned-char -fno-short-double -Os -I"C:\Program Files (x86)\Flowcode\Compilers\pic16\support\h" -I"C:\Program Files (x86)\Flowcode\Compilers\pic16\" -std=gnu99 "Auto_Lifting_Lamp_CTL_230619-01-Up_Speed".c -o "Auto_Lifting_Lamp_CTL_230619-01-Up_Speed".o
Options have been disabled due to restricted license
Visit http://www.microchip.com/ to purchase a new key.
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\includes.c:422:0,
                 from C:\Share\Project\Ing\201008-SJ_HiTech-Auto_Lifting_Lamp_CTL\Program\Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.h:979,
                 from Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:20:
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_FLASH.c: In function 'ReadFlash':
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_FLASH.c:452:33: warning: cast to pointer from integer of different size
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\includes.c:518:0,
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c: In function 'FC_CAL_I2C_Master_Init_1':
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:148:3: error: 'TRISA' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:148:3: note: each undeclared identifier is reported only once for each function it appears in
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c: In function 'FC_CAL_I2C_Master_Uninit_1':
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:256:3: error: 'TRISA' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c: In function 'FC_CAL_I2C_Master_Start_1':
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:280:3: error: 'TRISA' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:283:3: error: 'LATA' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c: In function 'FC_CAL_I2C_Master_Restart_1':
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:317:3: error: 'TRISA' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:321:3: error: 'LATA' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c: In function 'FC_CAL_I2C_Master_Stop_1':
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:355:3: error: 'TRISA' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:355:3: error: 'LATA' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c: In function 'FC_CAL_I2C_Master_TxByte_1':
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:401:5: error: 'TRISA' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:405:5: error: 'LATA' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:413:12: error: 'PORTA' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c: In function 'FC_CAL_I2C_Master_RxByte_1':
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:474:3: error: 'TRISA' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:483:12: error: 'PORTA' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_I2C.c:489:4: error: 'LATA' undeclared (first use in this function)
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c: In function 'FCD_0f641_DS18B20__WriteDevice':
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:3889:3: warning: passing argument 2 of 'FCD_0bbd1_One_Wire__MatchROM' discards qualifiers from pointer target type
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:458:6: note: expected 'MX_UINT8 *' but argument is of type 'volatile MX_UINT8 *'
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:3900:3: warning: passing argument 2 of 'FCD_0bbd1_One_Wire__MatchROM' discards qualifiers from pointer target type
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c: In function 'FCD_0f641_DS18B20__GetTemperature':
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:4232:3: warning: passing argument 2 of 'FCD_0bbd1_One_Wire__MatchROM' discards qualifiers from pointer target type
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c: In function 'FCD_0f641_DS18B20__SampleAddressedDevice':
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:4314:3: warning: passing argument 2 of 'FCD_0bbd1_One_Wire__MatchROM' discards qualifiers from pointer target type
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c: In function 'FCM_Cal_YUL262RTX':
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:11142:5: warning: passing argument 1 of 'FCD_01211_CircularBuffer1__GetArray' discards qualifiers from pointer target type
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:3187:6: note: expected 'MX_UINT8 *' but argument is of type 'volatile MX_CHAR *'
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:11151:5: warning: passing argument 1 of 'FCI_LEFTSTRING' discards qualifiers from pointer target type
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_String.c:170:18: note: expected 'MX_STRING' but argument is of type 'volatile MX_CHAR *'
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:11151:5: warning: passing argument 4 of 'FCI_LEFTSTRING' discards qualifiers from pointer target type
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:11152:5: warning: passing argument 1 of 'FCI_STRING_TO_INT' discards qualifiers from pointer target type
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_String.c:676:18: note: expected 'MX_STRING' but argument is of type 'volatile MX_CHAR *'
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:11157:5: warning: passing argument 1 of 'FCI_MIDSTRING' discards qualifiers from pointer target type
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_String.c:140:18: note: expected 'MX_STRING' but argument is of type 'volatile MX_CHAR *'
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:11157:5: warning: passing argument 5 of 'FCI_MIDSTRING' discards qualifiers from pointer target type
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:11158:5: warning: passing argument 1 of 'FCI_STRING_TO_INT' discards qualifiers from pointer target type
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:11163:5: warning: passing argument 1 of 'FCI_RIGHTSTRING' discards qualifiers from pointer target type
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\/PIC16BIT\PIC16BIT_CAL_String.c:193:18: note: expected 'MX_STRING' but argument is of type 'volatile MX_CHAR *'
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:11163:5: warning: passing argument 4 of 'FCI_RIGHTSTRING' discards qualifiers from pointer target type
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:11164:5: warning: passing argument 1 of 'FCI_STRING_TO_INT' discards qualifiers from pointer target type
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c: In function 'main':
Auto_Lifting_Lamp_CTL_230619-01-Up_Speed.c:13730:2: warning: 'return' with a value, in function returning void
Error returned from [xc16-gcc.exe]
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC16\batchfiles\pic16_C30_comp.bat reported error code 0x1
Autoclose turned off
FINISHED
Has thanked: 704 times
Been thanked: 768 times
Re: Compile error after FC10 update
I have placed your compiler output within code tags.
Can you please do that in the future.
It looks like the I2C master has not got the correct pins assigned.
If that is not the case then if you post your project, we can help you further.
seokgi
Flowcode v10 Re: Compile error after FC10 update
Post by seokgi »
After updating FC10, the I2C pin assignment is changed, resulting in a compilation error. I mapped to B14 (SDA) and B15 (SCL), but after the update, it is changed to A14 and A15. Other pins remain unchanged.
Re: Compile error after FC10 update(Solved)
Hi.
We are aware of an issue occurring with the SPI and I2C after a recent update.
This is being looked into.
