Hello Matrix Team,
I have used BME280 component with different PIC project is the past too.
Unfortunatly it is not possible to use this component with ESP32.
Is this a known issue?
BR
Dirk
BME280 Barometer Component is not Compiling with ESP32
dvcam99
- Has thanked: 9 times
- Been thanked: 14 times
- Has thanked: 665 times
- Been thanked: 744 times
Re: BME280 Barometer Component is not Compiling with ESP32
Hi Dirk
Can you please post with a 9 or 10 post icon so we know which version of Fowcode you are referring to?
Once I know which version you are referring to, I can look into the issue further.
No problem.
I can confirm the BME280 is compiling and working for me with FC9 & ESP32 TTGO, therefore, I have moved the topic from bugs.
Can you please post (or PM me if sensitive) your fcfx project and your .msg.txt files
Can you compile a blank exp project?
Can try the project in a new folder e.g. C:\ESP32 projects and try again?
