LIN BUS Component faulty (SOLVED)
Chip7882
Has thanked: 2 times
Been thanked: 3 times
Post by Chip7882 »
Hi Flowcode team,
I have problems with the LIN bus component. I use a PIC18F25K80.
When I try to send a simple message as a LIN master, it looks like this (see screenshot). There seems to be quite a long break between the individual bytes (20ms). There are also problems if I only send the header to get a response from a slave
Could you help me please?
Best regards
Daniel
Has thanked: 635 times
Been thanked: 842 times
Re: LIN BUS Component faulty
Hi Danial,
Please can you attach your programs and I'll investigate for you.
Chip7882
Post by Chip7882 »
Hi Ben,
thanks for your quick help.
Here are the files...
Micro_CAN_LIN_test.fcfx
(39.65 KiB) Downloaded 453 times
It looks like it's working ok but it's waiting a long time for an ack after sending each byte due to a timeout. I'm guessing the slave device isn't connected or isn't responding. If the slave is there then it might start appearing more usual.
The Receive Timeout property doesn't seem to be being used and instead there are timeouts of 10ms everwhere so I can look at this if that would help.
Chip7882
Post by Chip7882 »
Hi Ben,
You're right. I wasn't aware that every byte is acknowledged. Have now tried it with the slave and it works great. The timeout setting is not a problem. Thank you for your help and the great support!
Daniel
