In a old topic we have already written about a follower for the MPU9250, the ICM-20948.
https://flowcode.co.uk/forums/viewtopic.php?f=9&t=342
I have looked at the datasheet.pdf and migration.pdf from ICM-20948
As if the ICM can do much more than the MPU.
Something disturbing is just the supply voltage of the new IC
The ICM-20948 is only made for 1.95Volt.
But the following breakout board should manage this:
Sparkfun Breakout board SEN-15335 should work up to 3.3 volts.
https://www.sparkfun.com/products/15335
Adafrui Breakout board should work up to 3.3 volts. (5Volt?)
https://www.adafruit.com/product/4554
Maybe we should look more at the new ICM-20948 ?
Migrating from MPU 9250 to ICM 20948
- Has thanked: 223 times
- Been thanked: 240 times
- DS-000189-ICM-20948-v1.5 (2).pdf
- (1.5 MiB) Downloaded 507 times
- AN-000146-v2.0-TDK_Migration_MPU_9250toICM-20948 (3).pdf
- (329.39 KiB) Downloaded 495 times
- Has thanked: 590 times
- Been thanked: 778 times
Re: Migrating from MPU 9250 to ICM 20948
Hi Stefan,
I was just about to buy one and then I looked and noticed I already had one from the last time it was suggested. It's now sat on my desk and I'll see if I can find some time to have a play and make a component around it.
Is there already a version of the components to test?
