GLCD(Font Parameter error) (SOLVED)
niedian
- Has thanked: 3 times
- Been thanked: 5 times
GLCD Macro Font Parameter error.FontSet it to ranges from 1 to 311-31.But the font size does not change in the simulation. This is so wrong for all GLCD macros.Please help me. Thank you
- Has thanked: 529 times
- Been thanked: 719 times
Re: GLCD(Font Parameter error)
You only have one font defined for your display (in the display component properties) and so the font parameter for the Print macro should be 0. If you want to be able to scale the font from it's default size then use the SetFontScaler component macro.
