New component: PZEM-004T Power Monitor
Has thanked: 724 times
Been thanked: 783 times
Flowcode v10 New component: PZEM-004T Power Monitor
There are now a couple of examples on the Wiki
One is for the ESP32 TTGO, sending the data to the built-in gLCD
The other is for Arduino Uno, using the timer UART to output the data at a baud rate of 19200
The simulation will give 9's and that is expected.
When running on hardware the correct results should be obtained.
Has thanked: 839 times
Been thanked: 205 times
Flowcode v10 Re: New component: PZEM-004T Power Monitor
Post by jgu1 »
Hi Martin!
Thank you, I just order a couble Yesterday, so very convenient. Look forward to test
Br jorgen :D
Hi Jorgen.
You're welcome.
I have just added some notes and a warning on the Wiki.
They are great units.
One application could be to monitor an extension lead and sound an alarm if exceed the rating.
I also use it to monitor mains supplied by my consumer unit.
The energy can be monitored so the price of energy can easily be calculated.
I'm thinking of adding that to the examples.
Can you let me know how you get on, please?
Post by jgu1 »
Hi Martin!
Concerning Wiki, thank you for info, I will have a look, and look at your examble. :D
Would be nice with price calculation too.
It seems to be an exciting unit, which is also why I ordered one right away. I ordered on Ebay so it may take a while before I receive the package. The moment I have the module I will test it and you will be the first to hear the result. In the meantime, I start getting ready to
have the program ready with Lcd display and arduino.
By the way, can I use ESP 32 TTGO wihtout have ESP IDF ver 5.0?
So far thank´s ;)
Br Jorgen
Has thanked: 616 times
Been thanked: 815 times
Yes this should work fine in the default IDF v4.1.
Hi Jorgen.
You're welcome.
In addiiton to bens reply.
For anyone reading this topic. I can confirm I have tested with both V4.1, 4.2 and 5.0
It works for all three versions.
So whichever version you have, there is no need to switch.
Post by jgu1 »
Hi Ben and Martin!
Thank`s I Will order a ttgo too :D
In meanwhile I wait for the module I am starting on a testprogram with the PZEM module with a LCD display, later I att. the program and maybe you could have a look at it and check If it is possible what I do or not, so far it work in simulation :D
Br Jorgen
Has thanked: 442 times
Been thanked: 661 times
Hi Jorgen
If you take a look at Flowcode App Developer you will find under free apps a complete working example of using the module. This connects to your PC running FAD via WiFi.
It may give you some pointers, and I can confirm that Martin's component is very easy to use allowing you to customise things to your needs. I'm really tempted by the TTGO too, but having loads of 16x2 displays I can't really justify the need vs cost :(
Post by jgu1 »
Hi Chipfryer!
Well ok I will have a look, thank´for hint. Yes I also have a lot of LCD display, so I understand you, but I already order a TTgo, so look forward to test Martins project. :D
As mention, while I wait for delevery I have made a testprogram with a LCD display, only test so not all parameter is added, maybe you and /or Martin will take look at my testprogram for see if I am totally "on wrong way" :lol:
Br Jorgen
PZMLcd.fcfx
(15.6 KiB) Downloaded 521 times
Hi Jorgen
Your chart is pretty similar to the one I made to test functionality. In it I read every value and displayed, set a threshold, and if threshold was breached I'd reset the Energy. Purely as a test, and it worked fine.
I'm sure you will have similar success.
