Morning All,
Not used my ECIO's for a long time and having some issues, and confused what the issue(s) could be.
Installed the 64 Bit Drivers for the 28 & 40 P and trying to compile to target the USB HID example on the V9 wiki
https://www.flowcode.co.uk/wikiv9/index ... D_Keyboard
First issue ?
plugging in my ECIO to check windows detected it :-
Have tried a different port and get the same message.
Have tried the same lead on my electronic load and it works ok.
So i thought maybe because flowcode not open, so i opened it
When i checked the project options to try and change to mloader as my default is a pickit3 - was greeted by this message :-
My ECIO is set to USB Power on the Link & the green led flashes
running mloader i get this but forget what to do next, seams like everything knows its there
Any idea's
ECIO 40P Issues
steve001
- Has thanked: 81 times
- Been thanked: 30 times
Re: ECIO 40P Issues
Afternoon All,
Having Problems Still.
Very hit and miss if my ECIO programs or not, pressing "compile to chip"
Title:
Description:
Device: PIC.18F.ECIO-40
Generated by: Flowcode v9.3.1.36
Date: Sunday, July 23, 2023 12:30:49
Users: 1
Registered to:
Licence key:
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\bin\xc8.exe --chip=18F4455 "USB_HID_Keyboard.c" --MSGDISABLE=359,1273,1388 --CODEOFFSET=800h --ROM=default,-0-7FF
C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\pic\bin\picc18 --chip=18F4455 USB_HID_Keyboard.c --MSGDISABLE=359,1273,1388 --CODEOFFSET=800h --ROM=default,-0-7FF
Microchip MPLAB XC8 C Compiler V2.10
Build date: Jul 30 2019
Part Support Version: 2.10
Copyright (C) 2019 Microchip Technology Inc.
Employing 18F4455 errata work-arounds:
* Corrupted fast interrupt shadow registers
* No stopping on H/W breakpoints after NOP2
USB_HID_Keyboard.c: FCM_ASCIIToKeypress()
1147: case '£':
^ (226) char const too long
(908) exit status = 1
C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\bin\xc8.exe reported error code 0x1
Autoclose turned off
FINISHED
[/code]
Dont understand what is going wrong
at the moment mloader is seeing the ECIO and the LED is flashing (dose this mean its connected to mloader) ?
Device manager is showing it the ECIO logo is green
I am unable to compile to chip or to hex
Any idea's
Title:
Description:
Users: 1
Registered to:
Licence key:
1147: case '£':
FINISHED
[/code]
Any idea's
- Capture 23.07.23.PNG (93.71 KiB) Viewed 4349 times
- USB_HID_Keyboard.fcfx
- (35.7 KiB) Downloaded 475 times
- Has thanked: 724 times
- Been thanked: 783 times
Re: ECIO 40P Issues
Hi Steve the '£' ect is a part of the extended ASCII set and that is what's causing the error.
If you disable the Switch icon that contains '£' and any other extended chars, you should find it compiles OK.
Re: ECIO 40P Issues
Hi Martin,
Thank you.
Would you be able to modify the example file in the V9 wiki please?
I am not 100% sure and don't feel confident i can modify my chart correctly as i am stepping through and trying to get my head around what happening and why.
Thank you.
- Has thanked: 442 times
- Been thanked: 661 times
Re: ECIO 40P Issues
Hi Steve
In the ASCIItoKeypress Macro chart you will see two decision switches. The first has options for 0-9, the second with characters such as ")" etc.
If you open up the properties for this switch and change "£" to say "+" or any other non extended character i.e. anything decimal 0-127 then it should compile fine.
ASCII codes are here https://www.asciitable.com/
Re: ECIO 40P Issues
Hi All,
The application that i was wanting to use this for has, changed this is no longer required.
This project is of interest to me so i will have a go later
Thanks for the advice so far.
I will pick this up again at some point
