Compiler erros
WingNut
Has thanked: 53 times
Been thanked: 37 times
Flowcode v10 Compiler erros
Post by WingNut »
Good morning. I've just opened a file I haven't used for a while to make a minor change (display background colour). I'm getting undefined tris and port errors reported back. Not sure if this is related to the core up date or not as I haven't used this file for a while. The file compiles in FC9 ok.
N
ili9341 spi clock_with temp PCB_no_sd.msg.txt
(4.15 KiB) Downloaded 273 times
Has thanked: 278 times
Been thanked: 445 times
Re: Compiler erros
It could be that the pin connections for some of the components have changed. Please check those. Also check your library updates are up-to-date.
If there's still an issue, post your fcfx project (or PM me if it's sensitive) and I will investigate.
Has thanked: 228 times
Been thanked: 244 times
Re: Compiler erros
Hi WingNut, Hi Steve
I also had to re-enter the pins from the display,
but also remove a component from the hardware SPI channel1 and use the software mode instead
viewtopic.php?f=5&t=2059&p=12425#p12425
WingNut
Re: Compiler erros
Post by WingNut »
Yes one component so far unconnected (RTC module) and it now compiles but I'll have to go through the whole circuit as there appears to be other issues
