Trigonometry functions for ESP32
MJU20
Has thanked: 105 times
Been thanked: 76 times
Flowcode v10 Trigonometry functions for ESP32
Post by MJU20 »
Is the ESP32 able to perform accurate trigonometry functions with FC10? I'm trying to use some ordinary cosine and sine functions, but I'm getting strange results.
Could there be something in the FC10 documentation (Wiki) that states if it uses radians instead of degrees?
Has thanked: 616 times
Been thanked: 815 times
Re: Trigonometry functions for ESP32
Cos and Sin programming functions will generally always use radians rather then degrees. Hope this helps. If you like you can convert your degrees to radians by multiplying by 0.0174533.
If it's still being strange then let us know and I'll investigate.
MJU20
Post by MJU20 »
Thanks BenR, can some please put the fact that these values are in radians on the Wiki?
For future generations?
Yes I've done that for you now, let me know if this is ok.
https://www.flowcode.co.uk/wiki/index.p ... _Functions
