ESP32-Lolin-Lite UART
Has thanked: 425 times
Been thanked: 646 times
Flowcode v10 ESP32-Lolin-Lite UART
Just noticed that on the above chip I have UART options for Software and Channels 1-3. However irrespective of what I select, the pins cannot be changed from $PORT.B2 and B1 for Tx/Rx (even if Alt Pin is enabled).
Using latest FC with updated DB.
Has thanked: 575 times
Been thanked: 757 times
Re: ESP32-Lolin-Lite UART
We've locked Uart channel 1 to port pins a1 and a3 as they are used for both reprogramming and for debug. Do you need three uarts or can you use one of the other hardware channels.
It doesn't matter what channel I select, the actual pins cannot be changed. Channels 1-3 and software all use $PORT.B2 / 3
Has thanked: 695 times
Been thanked: 767 times
Hi.
Thank you for reporting this bug.
Can you try with the attached component, please?
For anyone who wants to try but does not know component locations.
Browse to this location using file explorer, it's hidden by default so just paste the link into your address bar.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
save the attached component in the above location
If Flowcode is already open, then you will need to reload your project for the new components to work.
RS232.fcpx
(90.63 KiB) Downloaded 328 times
Travelling, so will try later in week but I'm sure it will be good :)
