CRC-16 Component
Has thanked: 177 times
Been thanked: 1027 times
Flowcode v10 CRC-16 Component
Post by mnfisher »
The current project I'm currently working on needs a CRC-16 calculating for a block of data.
Given the polynomial (0x8005 in my case) - who knew that there was such a wide range of possible CRC calculations possible. For the given polynomial there were several possible CRC 'functions' possible - and my first attempt gave the wrong result.
So - I wrote a small component - this allows the user to set the polynomial, initial CRC, whether it is 'reversed' (refIn and refOut = true - note this only supports refin == refout) and a final value to XOR the result with. I've tested a range of values against https://crccalc.com/ - and seems to work correctly (more testing please ~:-) )
The initialise macro generates the lookup table for the given polynomial.
It would be possible to extend to CRC-32 if anyone needs this?
There is also a very simple test program - run in simulation - that generates the CRC for a small (5 byte) block of data.
It only supports data blocks up to 255 bytes - this could be extended if needed?
CRC16.fcpx
(2.19 KiB) Downloaded 903 times
crc_test.fcfx
(8.21 KiB) Downloaded 839 times
Landlweg
Re: CRC-16 Component
Post by Landlweg »
Dear Martin,
i think i need this programm
i have to transmit 9 byte data with CRC16 plynom 0x8408
can you help ?
Hermann
Landlweg
Post by Landlweg »
Sorry i will work with a PIC16F18877,
Hermann
Post by mnfisher »
It should work okay. Add the component and set the polynomial on the properties.
Let is know how it goes.
Landlweg
Post by Landlweg »
Hi Martin,
thank you for help
but in what way i can include it in Flowcode V10
the extension is normal for Flowcode *.fcfx
but this have *fcpx ?
Hermann
kersing
Has thanked: 81 times
Been thanked: 65 times
Post by kersing »
It’s a macro which you can import.
Has thanked: 800 times
Been thanked: 866 times
Place the fcpx within a folder of your choice.
Within Flowcode select File > Global settings (bottom left) > Locations tab
Within look for components in... window, add the path of the folder where you placed the fcpx file.
Note if you are going to have subfolders then place a semicolon at the end.
Select OK, save and reload your project.
Any components placed within the folder you just added should now be accessible.
Post by mnfisher »
Thanks Martin,
Yes - it is a component. Set the polynomial value in the component properties (and reverse / final XOR value if needed)
Call Initialise (once) - this calculates the lookup table for the CRC calculations
You can then pass an array of bytes to it (any length up to 255) and it's size to CRC16. As mentioned above - I used crccalc.com to check the results.
Landlweg
Post by Landlweg »
Hi Martin,
Sorry - what i make wrong
to import a makro it must have extensione *fcm ?
Hermann
Post by mnfisher »
Hi Hermann,
Follow Martin's (medelec's) post above to install the component - then add the component to your code ('components' - search for CRC16) - then you can use the macros from CRC16 (in the components tab of the project explorer)
What are you trying to do - I'll try and create a demo and some more instructions if needed.
