Sorry - my know how is to small
i have attach the file CCITT16-02.fcfx
for this databytes i have to calculate the checksumme
CRC16 Polynominal 0x8404 and invert the result in two bytes.
with PIC16F18877, he have a funktion for Cylic redundancy check (CRC) Module
but if is working with software is also O.K
the endresult must be O.K
can you please help ?
Hermann
CRC-16 Component
- Has thanked: 105 times
- Been thanked: 516 times
Re: CRC-16 Component
Hi Hermann,
First save the .fcpx file (from the first post) into a directory (for example c:\Flowcode)
Then add this directory to Flowcode's search using 'Build->Customise-Locations'
Okay I have G:\Flowcode (it's a long story - you're probably using C:\ )
Then you need to have your data in a byte array - I've modified your code to do this: I;ve set the polynomial to 0x8404 - if you need to invert the CRC you can either change the value of XorOut to 0xFFFF
or use the ~ operator (and do .crc = ~.crc) Martin
hi there
i am new to this forum so i hope posting here is ok?
i have been looking into generating 8 bit crc's from 6 8 bit bytes. i have flowcode 9 and was hoping to experiment with your crc component
but i cant get it to appear in the components list. i added the path to flowcode as described but no joy.
thanks from steve
thanks from steve
- Has thanked: 168 times
- Been thanked: 279 times
hi steve
thanks for the reply. i wondered if that may be the case.
cheers,
steve
cheers,
steve
Hi Steve,
Sorry i was ill.
Thank you for help
But the result is always wrong
i have for example 9 databyte,
4d 56 57 02 80 00 19 00 00,
CRC-CCITT16 Polynom 0x8408,
the result from other system inverted is 69 CD,
Do you have a good idea ?
i have Flowcode V10,PIC16F18877,
Hermann
Sorry i was ill.
Thank you for help
Hermann
Hi Herman,
I checked using the online checker - mentioned in the first post. There seem to be a range of algorithms / polynomials - and 0x8408 isn't one on that site.
If you can post (or PM) your code = and result you are getting I'll take a look and see if i can work out what is going awry..
Thank you Herman for creating this component.
I've played around much with various CRC8's and CRC16's on various projects in the past, with some micro's sporting a hardware CRC engine and others not, so will doubtless be of great use to many people
crccalc.com is nice and simple, though just giving a shout to the CRC location of Sunshine's website that I've used many times to validate calculated CRC's, with further explanations/information/features...
http://www.sunshine2k.de/coding/javascr ... rc_js.html
