Array initialiser out of bounds - crash
Has thanked: 177 times
Been thanked: 1026 times
Flowcode v10 Array initialiser out of bounds - crash
Post by mnfisher »
So - create a simple array a[3] of bytes (size and type probably irrelevant)
Initialiser of {1,2,3} works perfectly.
Unfortunately so does {1,2,3,4} - however this causes bad things to happen - saving and reloading locks Flowcode.
Adding a macro Test(array) - passing the array closes FC on debug - but gives an error (array index out of bounds) or crashes on adding the call to Test.
Note that it only allows 1 extra byte (or value) - so {1,2,3,4,5} gives initialiser error.
I miscounted and pasted a chunk of data....
Array.fcfx
(7.63 KiB) Downloaded 234 times
Has thanked: 311 times
Been thanked: 479 times
Re: Array initialiser out of bounds - crash
Thanks, Martin. I will add it to my list and fix in a future update.
