Global Settings is not available (Solved)
Sasi
Has thanked: 43 times
Been thanked: 15 times
Flowcode v10 Global Settings is not available (Solved)
Post by Sasi »
I downloaded version 10 to try but haven't bought it yet.
I find that the Global Settings menu item is missing from the File menu. Is this a bug or am I looking in the wrong place?
Sasi
Has thanked: 442 times
Been thanked: 661 times
Re: Global Settings is not available
When you first open FC and see options to create a new project or open an existing, you will see an icon for Global Settings on top left.
If you are already within FC then if you click on File you will see Global Settings at bottom left.
Hope this helps
Sasi
Flowcode v10 Re: Global Settings is not available (Solved)
Post by Sasi »
Wow, I didn't see that.
Thank you very much for your help.
You're welcome. Sometimes when software is upgraded things change and we need to go hunt things down :)
