Trying to use the BH1750 light sensor with an ESP32-Lolin.
First issue was pin remap.
Although within FC I can remap I2C pins for Ch1 / Ch2 / Software, I couldn't move them to pins IO34/35. Analyser confirms no activity on these pins.
From datasheet it has Hardware Ch1 on pins IO00/04 and using FC Ch1 on these pins an analyser shows activity and the returns a value of 1792 irrespective of whether the sensor is connected or not.
With Software Ch on these pins there is no activity on the pins.
Datasheet has Ch2 on IO15/02 and analyser shows activity with a return of 45824 irrespective of whetherthe sensor is connected or not.
The sensor works fine on a Pico (thanks to Medelec35) so it's good.
Not having used I2C on an ESP32-Lolin before I then attempted to use an OLED based on a SSD1306 that I've used many times before. A simple "Hello World" string was created with the display on Ch1 (IO00/04) and this worked perfectly.
BH1750 & Lolin
- Has thanked: 478 times
- Been thanked: 713 times
