Will install newer version Python corrupt ESP-IDF toolchain?
MJU20
Has thanked: 105 times
Been thanked: 74 times
Post by MJU20 »
I've been using the suggested installation of the ESP-IDF toolchain on the FC website. Even used the suggested version for Python! :-)
But now there are reasons to update Python to it's latest version.
Will this impact the ESP-IDF function for Flowcode?
I hate to fix something that works until it's broke..
Has thanked: 404 times
Been thanked: 625 times
Re: Will install newer version Python corrupt ESP-IDF toolchain?
I'm very much with you on the "if it ain't broke don't fix it" thought.
I'm using latest Python without apparent issue (yet) and have also recently changed ESP versions but when doing that I usually uninstall, reg-clean then reinstall. Not had much problem when doing that.
Perhaps create a System Restore point first?
Good luck.
kersing
Has thanked: 81 times
Been thanked: 65 times
Post by kersing »
The latest Python has some breaking changes that might well impact the toolchain. Can’t you install it in a separate location that is not part of your standard path so it doesn’t mess up the ESP toolchain?
On my W8.1 I'm running ESP toolchains pretty much as described with Python3.8.x without any issue, and on my W10 machine running ESP 5.1.1 I'm running Python 3.11.x (not sure what x-equals, not at machine, but download within the last month or so) and haven't noticed anything, yet.... What am I likely to find as a potential problem so I can look out for it?
I appreciate I might never have an issue but keen to know what to look out for.
Thanks in advance.
MJU20
Post by MJU20 »
I'm sorry: always forget to check "notify when reply"...
Thanks for the answers!
