ESP32, sd-card, file append is not correct
Has thanked: 246 times
Been thanked: 258 times
i did some tests.
Creating a file works well.
appendINTArray not ok. strange data saved
append string not ok. strange text saved
As an example I wrote the string "1234567890".
The result is 10 strange characters in the file.
Append string
bad test result on file
bad test result second time (with lower speed.)
Re: ESP32, sd-card, file append is not correct
Today I have tested again.
I have written a new program, just to test the file function
append string works
append array is not working correct.
it looks like one byte of the two bytes from an integer is not written correctly to disc.
append string is ok
Testprogram
Test_sdcard_buffer1.fcfx
(34.35 KiB) Downloaded 309 times
