Ili9341 seriel versus SPi and parallel!
Has thanked: 758 times
Been thanked: 187 times
Post by jgu1 »
Hi!
First, Flowcode Ili9341 component working excellent ;) but:
I have made a test on the Ili9341 display with diferent communication mode. I use a Stm32F0308. The fastes device I can find. I see other who use Arduino IDE is much faster.
Seriel Ok fast.
Spi, very slow
Parallel, approx. same speed as seriel.
I though, that Spi and parallel is the fastest. Is the above ok, I mean is it the Seial always will be the fastest? :|
Equal in simulation but not in real world.
Thank´s in advance
Jorgen
308 SPI ILI.fcfx
(17.52 KiB) Downloaded 511 times
Has thanked: 529 times
Been thanked: 719 times
Re: Ili9341 seriel versus SPi and parallel!
Hi Jorgen,
They should go like this in order of slowest to fastest.
Software SPI
Serial
Hardware SPI - With a low prescaler
Parallel
For the parallel mode did you have Use Ports ticked and have a complete port loaded? If you can't use a complete port for the data then yes this will have a similar speed to Serial as you loose the speed advantage.
Post by jgu1 »
Hi Ben!
Thank you.
Yes for parallel I have rolled all pin out.
Br Jorgen
