Modbus Issue.
seokgi
Has thanked: 8 times
Been thanked: 8 times
Modbus Issue.
Post by seokgi »
I am developing equipment for industrial use. I can't use C language, so I use FC10 to develop equipment.
The developed equipment was installed today, but was rejected by the customer. The reason is that the Modbus/RTU Master
reads data from the device too slowly, so the data is not read properly and transmission is also very slow (5~7 SEC).
Modbus/RTU Slave works well. It works well with HMI equipment or the Modbus Poll program on a PC.
And Modbus/TCP Master and Slave also operate very slowly.
Quick improvement is needed.
Please help me.
Thank you.
Has thanked: 616 times
Been thanked: 815 times
Re: Modbus Issue.
It shouldn't be this slow, sounds like maybe a timeout is happening. Can you share your project code or a cut down version of that shows the problem?
seokgi
Re: Modbus Issue.
Post by seokgi »
I am posting my project abbreviated here.
Please review carefully and point out my mistakes.
And please refer to the link as well.
https://flowcode.co.uk/forums/viewtopic.php?f=3&t=2117
https://flowcode.co.uk/forums/viewtopic.php?f=3&t=2148
Thank you.
230923_Freezer-MCU-Serial.fcfx
(151.58 KiB) Downloaded 523 times
seokgi
Re: Modbus Issue.
Post by seokgi »
I posted my project.
Could I apply your advice and test it over the weekend?
Thank you.
