Although flagged as v9 and example is written for v9 if opened in v10 it affects it too.
Basic chart simulating the MPU6050 component. It initialises then enters a loop. Inside the loop it samples the sensor then Gets all readings as both floating point and integer values.
Simulation speed = fast (with updates)
Temperature:
Component shows range of -40 to +80 and component display varies between -40 and +40
Floating point = 36.415xxx to 36.762xxx
Integer = constant 36
Gyro:
Component shows range of -250 to +250 and component display varies between -250 and +250
Floating point = -249.992xx to +249.992xx
Integer = -32766 to 32766
Above is for x/y/z with each axis returned to zero before next
Accelerometer:
Component shows range of -2 to +2 and component display varies between -2 and +2
Floating point = constant 0.0
As you can see there are issues in reading both temperature and Accelerometer "Real" values
MPU6050
- Has thanked: 478 times
- Been thanked: 713 times
- Has thanked: 795 times
- Been thanked: 858 times
Re: MPU6050
Hi.
If you are happy with the fix, the component modification will be pushed onto the update system ASAP.
If would you like to test before then, browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
If you run any component updates, then the components you added will be overwritten.
Can you let me know if it works for you, please?
C:\ProgramData\MatrixTSL\FlowcodeV10\ComponentsIf Flowcode is already open, then you will need to reload your project for the new components to work
- MPU6050.fcpx
- (5.83 KiB) Downloaded 475 times
Re: MPU6050
Just tried in v10 and it seems to be fine
. Hope to try on hardware later in the week.
